balanced
Posted: Wed Jan 19, 2011 1:23 pm
by mickdale
had a SIL flywheel lightened.
then had it cnc balance checked and it was found to be 7 grams out
flywheel has now been balanced
i would estimate the amount of metal removed was the equivalent of between a 10 and 50 pence piece
unfortunately i didnt check for balance before lightening as i would have had a good comparison - will do next time
worth thinking about if anyone getting a flywheel lightened on a lathe as balancing will dramatically reduce vibration
Re: balanced
Posted: Wed Jan 19, 2011 1:57 pm
by YAMLAM
well, when you do mine mate :D you can do a before and after comparison :!:
Re: balanced
Posted: Wed Jan 19, 2011 5:04 pm
by gaz_powell
who did the work ?
Re: balanced
Posted: Thu Jan 20, 2011 8:17 am
by mickdale
YAMLAM wrote:well, when you do mine mate :D you can do a before and after comparison :!:
:roll: how many lammys in the club lol
- gaz - got the operator at work to use one of the companies ones - was really suprised how far out a machined one was
Re: balanced
Posted: Thu Jan 20, 2011 6:35 pm
by Knowledge
I have no idea what the balancing machine would look like. Can you give me some clues?
Re: balanced
Posted: Thu Jan 20, 2011 11:06 pm
by mickdale
Knowledge wrote:I have no idea what the balancing machine would look like. Can you give me some clues?
no worries martin - will take a pic next week as off work tomorrow
this was how much needed removing to completely balance the flywheel!
Re: balanced
Posted: Fri Jan 21, 2011 10:56 am
by red ghost
Hey Martin, use ya Googles, there's heaps of boring videos on you-tube.. ;)
Re: balanced
Posted: Fri Jan 21, 2011 11:00 am
by red ghost
Ideally one would balance the flywheel,crank and front sprocket assembly all in one at the same time.. That's my top tip..
Re: balanced
Posted: Fri Jan 21, 2011 1:10 pm
by corrado
Are you sure that he just didn't drop it and broke a piece off? :P
Re: balanced
Posted: Fri Jan 21, 2011 3:40 pm
by shocky
red ghost wrote:Ideally one would balance the flywheel,crank and front sprocket assembly all in one at the same time.. That's my top tip..
on the old lactating forum a guy who went by the user name of AIG had his complete top end "dynamically" balanced, the thread might still be available
