balanced
mickdale
had a SIL flywheel lightened.
then had it cnc balance checked and it was found to be 7 grams out
flywheel has now been balanced
i would estimate the amount of metal removed was the equivalent of between a 10 and 50 pence piece
unfortunately i didnt check for balance before lightening as i would have had a good comparison - will do next time
worth thinking about if anyone getting a flywheel lightened on a lathe as balancing will dramatically reduce vibration
YAMLAM
well, when you do mine mate :D you can do a before and after comparison :!:
win or lose have a booze
gaz_powell
who did the work ?
mickdale
YAMLAM wrote:well, when you do mine mate :D you can do a before and after comparison :!:
:roll: how many lammys in the club lol
- gaz - got the operator at work to use one of the companies ones - was really suprised how far out a machined one was
Knowledge
I have no idea what the balancing machine would look like. Can you give me some clues?
Martin
mickdale
Knowledge wrote:I have no idea what the balancing machine would look like. Can you give me some clues?
no worries martin - will take a pic next week as off work tomorrow
this was how much needed removing to completely balance the flywheel!
red ghost
Main scooter: lambretta gp150
Hey Martin, use ya Googles, there's heaps of boring videos on you-tube.. ;)
red ghost
Ideally one would balance the flywheel,crank and front sprocket assembly all in one at the same time.. That's my top tip..
Are you sure that he just didn't drop it and broke a piece off? :P
red ghost wrote:Ideally one would balance the flywheel,crank and front sprocket assembly all in one at the same time.. That's my top tip..
on the old lactating forum a guy who went by the user name of AIG had his complete top end "dynamically" balanced, the thread might still be available
