keihin to imola
Twinny
Main scooter: suzuki 185
keihin measures 28.4mm inlet side
flat slide no.4
needle n99e , clip on top notch
pilot 60 measures 28.17mm in lengh
main 118 measures 16.4 long with 1/4 inch drive
air screw out 1 and 1/4
the carb body has v607
dj26 printed on it
the question is does anybody know a starting piont for jetting
imola 186 barrel , reaper high com head,new gori clubman 40mm, old lightened a/f flywheel
thanks in advance
Bofs
Got these settings off a mate who builds reputable engines, will get you going anyway.
Imola with JL3
30mm pwk main jet 140
pilot jet 36
needle n80f this should be standard clip p1
with remote filter.
Think the n80f equivalent is a JJH
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
sydduckett
Stick a delly on yer tight git.... ;) put kettle on ill be round for 3.45.... :D
    Users browsing this forum: Google [Bot], Semrush [Bot] and 2 guests
