MB Gearchange
wack 63
Main scooter: '71 GP TS1
I recently bought a new MB gearchange for drop bars but the clutch lever is far too long forcing my hand 3" down the shaft.Does anyone know if a shorter one is available?It looks similar to a Yamaha one you would use on a Ser 3 housing but normal Lamby ones wont fit. Part no MRB 0258K
a pic would be help full ,is it the mb one based on the vega casting??
wack 63 wrote:I recently bought a new MB gearchange for drop bars but the clutch lever is far too long forcing my hand 3" down the shaft.Does anyone know if a shorter one is available?It looks similar to a Yamaha one you would use on a Ser 3 housing but normal Lamby ones wont fit. Part no MRB 0258K
Sound like you need this one...
http://www.lambrettaspares.com/sparepar ... 0696k.html
wack 63
Yes that's the one.As you can see the lever is longer than the twist grip shaft and the finger grips are a long way from the pivot point.The other lever has a different angle where it meets the housing Soulsurfer.
a vega lever should still fit ....but dont take my word for it......... give mb a ring or on his facebook to check
Ian Hepworth
RICSPEED wrote:a vega lever should still fit ....but dont take my word for it......... give mb a ring or on his facebook to check
I doubt it, the casting is designed to suit the yam lever.
there you go ........all i can suggest then is go to a bike shop,take lever with you and ask to look at a hi-level catalouge(or some thing like,motrax maybe) and compare with other yamaha clutch levers
