Fuel gauge sender resistance
Posted: Wed Dec 22, 2010 4:34 pm
by spencerd
I am looking at fitting a universal digital dash display gauge....thingy to my T5 Classic & in order to set up the fuel gauge reading correctly I have to input the resistance of the sender unit (measured in ohms!!).
Can anyone advise?
Thanks, Spencer
Re: Fuel gauge sender resistance
Posted: Fri Dec 24, 2010 11:13 pm
by wack 63
I fitted an Acewell to my Lamby with a fuel gauge and just tried different settings till it worked.
Posted: Sat Jan 01, 2011 1:08 pm
by sugarlump
Presuming you have the fuel gauge sender, remove it from the tank. It should have two connections which go to the gauge, use a multi meter and measure the resistance with the float fully at the top and then fully extended at the bottom. Usually the range is either 0-70 ohms or 30-230 ohms.
Posted: Sun Jan 09, 2011 11:06 pm
by spencerd
Thanks for the responses folks
