Fuel gauge sender resistance
spencerd
I am looking at fitting a universal digital dash display gauge....thingy to my T5 Classic & in order to set up the fuel gauge reading correctly I have to input the resistance of the sender unit (measured in ohms!!).
Can anyone advise?
Thanks, Spencer
wack 63
Main scooter: '71 GP TS1
I fitted an Acewell to my Lamby with a fuel gauge and just tried different settings till it worked.
sugarlump
Presuming you have the fuel gauge sender, remove it from the tank. It should have two connections which go to the gauge, use a multi meter and measure the resistance with the float fully at the top and then fully extended at the bottom. Usually the range is either 0-70 ohms or 30-230 ohms.
spencerd
Thanks for the responses folks
