Front wheel nuts
Posted: Sun Dec 12, 2010 5:27 pm
by 10 inch Terror
Hi all, after recently losing a main front wheel nut i've decided to fit some nyloc nuts on my front wheels, could anyone tell me what pitch and size they are please?. Cheers Pete
Re: Front wheel nuts
Posted: Sun Dec 12, 2010 6:55 pm
by shocky
the proper ones should have nylon inside them its just hidden by the dome bit
there a metric fine thread and the size is M12 X 1.5MM pitch most M12 fastners have a 1.75MM pitch
there is also a metric fine fine thread at 1.25 MM pitch
Posted: Mon Dec 13, 2010 3:03 pm
by corrado
Unless you're refering to the nuts on the rims which are M8 with 1.25 pitch. That's standard M8.
Posted: Mon Dec 13, 2010 7:05 pm
by Muttley McLadd
Screwfix do them at a price so reasonable that they're a single use item.
Posted: Tue Dec 14, 2010 7:35 pm
by dirtyhandslopez
Muttley McLadd wrote:Screwfix do them at a price so reasonable that they're a single use item.
Nylocks are designed to be single use. One you take them off, the plastic lock will loose it's grippyness
