Front wheel nuts
10 inch Terror
Xbox live gamer tag: No.
Hi all, after recently losing a main front wheel nut i've decided to fit some nyloc nuts on my front wheels, could anyone tell me what pitch and size they are please?. Cheers Pete
the proper ones should have nylon inside them its just hidden by the dome bit
there a metric fine thread and the size is M12 X 1.5MM pitch most M12 fastners have a 1.75MM pitch
there is also a metric fine fine thread at 1.25 MM pitch
Unless you're refering to the nuts on the rims which are M8 with 1.25 pitch. That's standard M8.
Screwfix do them at a price so reasonable that they're a single use item.
dirtyhandslopez
Muttley McLadd wrote:Screwfix do them at a price so reasonable that they're a single use item.
Nylocks are designed to be single use. One you take them off, the plastic lock will loose it's grippyness
That's not going anywhere...
