Gearing
Moon the Loon
Hi,
Can i keep my standard sprockets (15/46) and original gearbox (Li 125 Special) for a Mugello 186 V4?
I've 28mm carb and clubman also.
Thanks.
WINTERMODEL150
Hi,you may find that it will rev very high with a mugello 186 kit on,think 16/46 will be a good starting point,it depends on what you want to use it for as well,around town it will be great ( i had this kit on a special 150) but on motorways 15/46 it will feel like you need another gear.
Hope this helps.
Dean.
lozmondo
Check out the gearbox visuliser, link on this site somewhere...brilliant at seeing how you can improve your gearing to suit your needs
Avantone
lozmondo wrote:Check out the gearbox visuliser, link on this site somewhere...brilliant at seeing how you can improve your gearing to suit your needs
<cough> here you go......
http://scooterotica.org/forum/viewtopic.php?f=7&t=6286
Tony
www.lambrettagearbox.com
