Corsa LX200 or PX200
Posted: Tue Nov 16, 2010 9:58 am
by dopeshots
Hi, what is the difference between a Corsa LX200 engine and a PX200 Engine?
My PX is needing a rebuild and I have seen a good Corsa LX200 engine second had for sale.
Cheers ;o)
Re: Corsa LX200 or PX200
Posted: Tue Nov 16, 2010 10:25 am
by timexit17
I think you mean Cosa.
I believe the engines are quite a bit different?
I know the brakes are linked for starters, Chuck from Bristol is the Cosa expert: I expect he's on here somewhere......
Posted: Tue Nov 16, 2010 10:43 am
by goldeneye
wont fit mate. casings are different, and wont fit in a p range frame without major jiggery pokery. if its in good condition , and cheap,buy it for bits. the barrel,piston,cylinder head , ignition system, gearbox ,clutch and crank all fit in p200 casings. plus all the small bits, studs, brackets etc. would make a good doner motor.
Posted: Tue Nov 16, 2010 1:02 pm
by Chuck
Expert - I am flattered!
Goldeneye is spot on. The casings are different, they have a wider and deeper beam where the engine bolt goes into but the internals are the same. Best bet is to tell me where it is and I will go and take it off their hands!!
Posted: Tue Nov 16, 2010 7:10 pm
by dopeshots
Thanks for the info guys, most helpful.
Cheers ;o)
