Corsa LX200 or PX200
dopeshots
Xbox live gamer tag: rms789
Main scooter: GP150
Hi, what is the difference between a Corsa LX200 engine and a PX200 Engine?
My PX is needing a rebuild and I have seen a good Corsa LX200 engine second had for sale.
Cheers ;o)
timexit17
Main scooter: GP 225 Extra S type
I think you mean Cosa.
I believe the engines are quite a bit different?
I know the brakes are linked for starters, Chuck from Bristol is the Cosa expert: I expect he's on here somewhere......
goldeneye
wont fit mate. casings are different, and wont fit in a p range frame without major jiggery pokery. if its in good condition , and cheap,buy it for bits. the barrel,piston,cylinder head , ignition system, gearbox ,clutch and crank all fit in p200 casings. plus all the small bits, studs, brackets etc. would make a good doner motor.
Chuck
Expert - I am flattered!
Goldeneye is spot on. The casings are different, they have a wider and deeper beam where the engine bolt goes into but the internals are the same. Best bet is to tell me where it is and I will go and take it off their hands!!
dopeshots
Main scooter: GP150
Thanks for the info guys, most helpful.
Cheers ;o)
