Choke cable adjustment
Posted: Mon Nov 15, 2010 1:03 pm
If the choke cable was too slack would I be right in saying that when the choke lever is turned on then it is possible that the choke is not engaging, causing engine start up problems.
If the cable was then over tightened, what problems might this cause, and what signs would tell me that it is too tight???
