Choke cable adjustment
Mr Ed
If the choke cable was too slack would I be right in saying that when the choke lever is turned on then it is possible that the choke is not engaging, causing engine start up problems.
If the cable was then over tightened, what problems might this cause, and what signs would tell me that it is too tight???
:oops: :oops: :oops: :oops: :oops:
Mr Ed wrote:If the choke cable was too slack would I be right in saying that when the choke lever is turned on then it is possible that the choke is not engaging, causing engine start up problems.
First question you answer yourself
Second question the bike would run very rich through the throttle positions as your choke would always be engaged
hope this helps :D
Knowledge
If you are running a Dell'orto, you should be able to see the plunger of the choke moving up and down through the apeture to the side of the main venturi. You might need a good light, but is quite easy to see the plunger operating.
If the cable is over-tight, then it might well pull-off the nipple at either end. The Lambretta choke operating mechanism has a very strong pull on it: far stronger than you might expect from a little lever.
If you suspect that your choke cable is an issue, I can make you a custom cable to suit your specific carb make and size (grey or black). £5 delivered for Scooterotica members.
Martin
    Users browsing this forum: Amazon [Bot] and 4 guests
