Will an "A" piston fit a "B" bore?
Posted: Tue Nov 02, 2010 10:53 pm
by Bofs
I need a new piston for my Imola kit.It`s a B stamped barrel. Will an "A" grade piston be ok?
Re: Will an "A" piston fit a "B" bore?
Posted: Tue Nov 02, 2010 11:06 pm
by RICSPEED
dont think so
Posted: Wed Nov 03, 2010 12:51 am
by TS1-200
If its any help I fitted a C grade piston in my TS1 (B grade barrel) or it might have been the other way round and it was fine, as I couldn`t get the correct grade at the time MB said it would be OK, and it was.
Posted: Wed Nov 03, 2010 1:22 am
by byron
I think you can go one grade either side...?
so mix A with a B, or B with a C, but not A and C
but wait for someone to confirm that....
Posted: Wed Nov 03, 2010 7:09 am
by CPH Lambretta
Thats what I was told as well :)
Posted: Wed Nov 03, 2010 9:16 am
by Bofs
Cheers folks, there only seems to be "A" grades available at the minute,hence the query.
Posted: Wed Nov 03, 2010 1:51 pm
by eibargum
Bofs wrote:Cheers folks, there only seems to be "A" grades available at the minute,hence the query.
Get the verniers out, ive had B,s bigger than C,s, :shock: , so you may find a A bigger than a B.
Posted: Wed Nov 03, 2010 2:51 pm
by shocky
byron wrote:I think you can go one grade either side...?
TINO told me that when he had my muggy replated he said a slight oversize was better it never gave me any problems altho it was standard and not that fast(200)
