Will an "A" piston fit a "B" bore?
Bofs
I need a new piston for my Imola kit.It`s a B stamped barrel. Will an "A" grade piston be ok?
Muffspeed....no muff too tuff
Bad Samaritans SC
1957 Zundapp Betta 500 Auto
dont think so
TS1-200
If its any help I fitted a C grade piston in my TS1 (B grade barrel) or it might have been the other way round and it was fine, as I couldn`t get the correct grade at the time MB said it would be OK, and it was.
Keep on keepin on
I think you can go one grade either side...?
so mix A with a B, or B with a C, but not A and C
but wait for someone to confirm that....
CPH Lambretta
Main scooter: DL 150 1970
Thats what I was told as well :)
Slow is the new fast!
Bofs
Cheers folks, there only seems to be "A" grades available at the minute,hence the query.
Bad Samaritans SC
eibargum
Bofs wrote:Cheers folks, there only seems to be "A" grades available at the minute,hence the query.
Get the verniers out, ive had B,s bigger than C,s, :shock: , so you may find a A bigger than a B.
byron wrote:I think you can go one grade either side...?
TINO told me that when he had my muggy replated he said a slight oversize was better it never gave me any problems altho it was standard and not that fast(200)
    Users browsing this forum: Semrush [Bot] and 31 guests
