An other Rally project
The prisoner
Main scooter: Serveta Jet 200
Hello, this is my Rally 200 project, often let alone because of Lambretta and you know what i mean :roll:
Try to be honest and let me know what do you think of the front (fork, disc conversion, mudguard...)
At the moment, not really sure if i continue this way.
Dazza
Like it..a lot.. Do the neighbours like the pitone though? :D
C*NTSPEED
looks good to me normal disc forks?
GEMINI S.C.
BLACK WIDDA'S S.C.
The prisoner
Neighbours don't seem to complain about the Pitone, it's not a baffleless.
I'm just asking myself if it's not my quieter scooter :lol:
The fork is an early PX one with an old semi-hydraulic conversion in 16 mm, now in fully hydraulic with second hand millenium master-cylinder (hence the broken lever at the moment).
Dryballs
Love the bike, but the guard is horrible!
Sorry, but PX forks make the whole front of the bike sit too high
Why not just get a PK fork and fit a standard front guard to it? they fit well and look almost standard!
Here is one I prepared earlier...
The prisoner
Dryballs,
it's me thinking too at the moment about whole front bike too high (especially with T5 mudguard).
That's why i asked about the Rally fork conversion made by Worb5...
Did you have a lot of modifications on your PK fork to accept the original mudguard (modified too?) and did you take some pictures?
It's a PK XL 2 fork i need for a Rally, isn't it? But front axle is in 20 mm then...
Thanks for opinion.
paulc
Dryballs wrote:Love the bike, but the guard is horrible!
is that hoover a toaster as well?
C*NTSPEED
but the pk fork does not fit striaght in now does it
i bought some pk 125 xl forks with disc attatched only to find i had to lengthen the fork stem to get it to fit
so never botherd ;)
GEMINI S.C.
BLACK WIDDA'S S.C.
Dryballs
I didnt have to do any modifications to this fork. The mudguard needs a spacer to make it sit right, but thats easy.
I put a PK fork into a super once and had to have the stem shortened. A good engineer can do this easily - cut the required amount out, put a spigot in and weld it!
SIP sell a fork already modified dont they?
Prisoner - I wonder if it is possible to swap the fork link over so you can still use your 16mm disc brake? or just sell yours and get a 20mm one
The only real dodgyness about my conversion is I used the PK shock and the holes dont line up with the brake caliper mount, so I had to use one bolt.
I see LTH make a spacer so you can use a shortened PX shock now days
damdam
Like your Rally a lot, but the T5 mudguard imho is 100% out of place
Even the Corsa seat is nice but too much P-range for a 70's style Rally 200
What about the engine? Standard? Kitted?
