Model C - Knuckel joint issues
Marc
I finished my model c two month ago. After a couple of kilometers the rear knuckle joint started to leak grease when the engine has warmed up. This was the only part of the engine I haven't touched in the first place because somebody told me it's to difficult.
Does somebody know how to get the cogs out and if a special tool is needed?
There is a bit of casing missing where the rear engine bolt / brake bolt goes (see picture) is this standard or has the large cog been rubbing against the casing?
cant see the pics mate
have a brouse in here -
http://www.forums.ilambretta.com/viewfo ... 4f7e767ffa
jimmers
cant see pics but recently took all mine apart to change bearingsseals and stuff in rear
may be able to help if i could see pics
cheers
Marc
trying to post the pictures again:
I think the seal between the gearbox and rear drive is gone, so when the engine gets hot the oil runs into the knuckle joint?!
    Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
