Gilera Runner VXR 200 Cutting out problems
Posted: Thu Sep 30, 2010 9:50 pm
by mr series 2
Hope someone can help with problems im having with a runner VXR 200 when coming to a stop the engine cuts out or if it does keep running it then cuts out when trying to pull away again is this a common problem has anyone else had this happen thanks in advance
Re: Gilera Runner VXR 200 Cutting out problems
Posted: Fri Oct 01, 2010 12:27 pm
by methleymongo
CHECK THAT THE AIR FILTER ISN'T BLOCKED OR REMOVE IT AND THEN TRY IT....
Posted: Fri Oct 01, 2010 9:04 pm
by mr series 2
methleymongo wrote:CHECK THAT THE AIR FILTER ISN'T BLOCKED OR REMOVE IT AND THEN TRY IT....
Thanks for that i will check it
