replacement imola reeds
sjc
looking to replace the reeds on my imola 186,,wot replacement ones can i buy and were from,,many thanks steve,,, ;)
soullad
sjc wrote:looking to replace the reeds on my imola 186,,wot replacement ones can i buy and were from,,many thanks steve,,, ;)
Have used replacement ones from Camlam, Boyesen dual stage from MB and also just cut them out of regular TS1 carbon items, thou guess it depends on your reedblock to an extent.
sjc
cheers soullad,,im runnin a standard imola reed block..cheers steve
psychedelicropcircle
new to this reed valve game...how long do they last and wot are the signs for renewing them?
dapper
Usually drop off in performance and increase in spitback through the carb. Normal signs are feathering at the edges of the reeds.
mickdale
does anyone know the difference in performance using different reedblocks? (eg dyno comparisons)
cheers
mick
also do you need to modify certain ts1/motorcycle designed reedblocks to fit the imola?
