throttle cable
Posted: Mon Sep 20, 2010 3:20 pm
by psychedelicropcircle
Building a imola 186 obviously the carb has moved to the kickstart side do I ;
A; need a new longer one?
B: Remove leggies and reposition to gain longer lenght?
moving from a standard set up.
Re: throttle cable
Posted: Mon Sep 20, 2010 6:43 pm
by 10 inch Terror
Just buy an extra long throttle cable and brass nipple from any dealer. I use MB ones and have never had any problems.
Re: throttle cable
Posted: Mon Sep 20, 2010 10:08 pm
by Knowledge
You might find your choke cable is too long as well. I can make you a replacement choke cable for a £5 delivered.
Re: throttle cable
Posted: Tue Sep 21, 2010 8:57 am
by 10 inch Terror
Knowledge wrote:You might find your choke cable is too long as well. I can make you a replacement choke cable for a £5 delivered.
I had Knowledge supply me with one. Perfect fit.
Re: throttle cable
Posted: Tue Sep 21, 2010 9:11 am
by joee
10 inch Terror wrote:Knowledge wrote:You might find your choke cable is too long as well. I can make you a replacement choke cable for a £5 delivered.
all knowledges kit is top quality
Re: throttle cable
Posted: Tue Sep 21, 2010 9:36 am
is the choke cable an inner/outer and how do i pay you.......needed as soon as
Re: throttle cable
Posted: Tue Sep 21, 2010 1:27 pm
by Knowledge
Hi,
You need to tell me what carb you are using (make and size), what colour outer (grey or black), and if you are using a traditional choke lever (I use an aftermarket choke lever from Dell'orto, but that's just me)
I'll send you my paypal address via pm.
Re: throttle cable
Posted: Tue Sep 21, 2010 3:43 pm
28mm dellorto phbh grey cable standard choke lever!
