throttle cable
psychedelicropcircle
Building a imola 186 obviously the carb has moved to the kickstart side do I ;
A; need a new longer one?
B: Remove leggies and reposition to gain longer lenght?
moving from a standard set up.
10 inch Terror
Xbox live gamer tag: No.
Just buy an extra long throttle cable and brass nipple from any dealer. I use MB ones and have never had any problems.
Knowledge
You might find your choke cable is too long as well. I can make you a replacement choke cable for a £5 delivered.
Martin
10 inch Terror
Knowledge wrote:You might find your choke cable is too long as well. I can make you a replacement choke cable for a £5 delivered.
I had Knowledge supply me with one. Perfect fit.
joee
all knowledges kit is top quality
randall ate my dog!!
no one likes us we dont care
is the choke cable an inner/outer and how do i pay you.......needed as soon as :lol:
Knowledge
Hi,
You need to tell me what carb you are using (make and size), what colour outer (grey or black), and if you are using a traditional choke lever (I use an aftermarket choke lever from Dell'orto, but that's just me)
I'll send you my paypal address via pm.
Martin
28mm dellorto phbh grey cable standard choke lever!
