Mikuni - where's mi nipple adjustment - ooh er missus
joolz
Evening chaps
I'm about to go into tinker mode (well next weekend) ..... new clutch, expansion, carb etc
Anyway re the carb...
I have a Mikuni copy to nail on.... it has come with an inner throttle cable.
Now all my Lambos have had Delorto/Jettex carbs where the adjustable nipple is at the carb end.
The Mikuni has the fixed nipple at the carb (AFAIK)
Sooooo.... can you get adjustable nipples at the throttle end and if so where from???
Or am I missing summat?
Thanks guys
Julian
joolz
Yer a bloody star Mark
AND
My local dealer too :-)
Thanks
So I guess you snip off the excess???
Anyway, trip to Notts in the morning
yes i normally snip it then solder up the end
joolz
mark wrote:yes i normally snip it then solder up the end
Top tip that man
Top tip ;)
Thanks
and, with an old brass pulley, leave enough spare to fit a spare nipple on the end.
it does also help to have some cable adjustment at the carb end, so maybe use an elbow with screw in adjuster ?
joolz
Bloody hell........... another top tip (or two)
Was wondering about the adjustment....
Will deffo take all this on board
Many thanx
J
