bulb blowing
nuttyboy
Main scooter: lambretta
hi, ive got a 150 special with 12 volt kit. not sure what make. keep on blowing headlight and rear bulbs. is it the regulator?
I was told that it was the regulator on mine but it appears to be a compatabilty issue between the BGM stator and the Ducati regulator as both tested fine and the lights are fine with the Ducati regulator and Indian stator.
WINTERMODEL150
Hi,make sure your speedo bulbs working as if this is its blown then normally it will blow the headlight or tail light bulbs,I normally wire the side light bulb into the tail light (black wire in headset) so its on all the time.
Failing that you could have a fault elsewhere .
Dean
It is usually the regulator
