rear hub bearing
Daggs
Has anyone had any experience of the Indian rear hub bearings ? Good or bad !
Bilko
Main scooter: LI150
I'd stick to what I know works. No bother for many years on RIV. Now using MBD's very own too.
Bilko's Oily Blog
dirtyhandslopez
I have had two that would not let the endplate shim up correctly. They were to tall, meaing if you laid it flat on the ground, it is taller than an original RIV bearing.
That's not going anywhere...
