Mikuni TMX 35 Carb Keeps Falling off
Red GP Rider
Main scooter: GP RB 240 Taylor Tuned
I have a Mikuni TMX 35 on my RB22 kit, once the engine gets really hot after a few miles the carb drops off from the back inlet manifold, there is a sufficient hole in my side panel, the running boards have been cut so there is no contact there either, i have offset cones on the engine mount and i have used both the MB thick rubber with the wider jubilee clips, i have also tried the thinner ones that are now on the market without no sucess, all of these have been tried with different pressure when tightening up the jubilee clips all to no avail.
The carb is the close to the engine mounts and the toolbox but the people i have spoken to never seem to have problems that i am currently encountering
can anyone help please?
Wayne Miller
Have you got a pic of your inlet manifold?
When using a rubber its always handy to have a groove or lip at the end of your manifold to give the rubber adaptor something to grip against
Stay tuned..............
ArmandTanzarian
Take the panel off and get your fattest friend to bounce on the suspension. You might find that its knocking on something. Mine was hitting the back of the toolbox. I fixed the problem by "adjusting" the shape of it with a lump hammer! (the toolbox not the carb!)
Funkspeed
Main scooter: Rally 200
What tank do you have fitted?
I had a stainless one but the cut out wasn't deep enough and the carb would fall off after catching on it a few times.
Red GP Rider
Funkspeed wrote:What tank do you have fitted?
thank for all the replies, it certainly gives me something to think about..........especailly the fat friend reaply........shall i ask him.......or will you? :P
drew2
i had this problem a bit ago,in my case
the rear brake cable was hitting the
carb so just re-routed the cable and
problem cured
Red GP Rider
Hi All
Many thanks for the replies, i have solved the problem, but had to cut the corner of the plastic toolbox away!!..........Doh! :?
but at least its trouble free at the moment :)
    Users browsing this forum: Semrush [Bot] and 14 guests
