hyd disk brake
oggy
getting fluid coming out past the ressy piston seals(new piston and seals),mate said that the calliper end piston might be stiff with dirt corrosion etc and this forcing the fluid back as its the weakest link,before i take apart dose this sound likeable(std inboard hyd brake) cheers
