HORN
RayRacer
How do I get a horn that doesnt sound like a dying duck?
I have a 12 volt AC system on my GP with Varitronic (90 watt).
I have tried a Stebel Magnum TM 80/1 which is 5.5 amp but that doesnt work.
Can I use a capacitor/relay/charge pump to help store energy for release?
You really need 12v DC from a battery.
doesn't the varitronic rectifier unit also put out some DC current ??
if so, run a wire from that to a 12v DC horn...
you can still use the handlebar switch to earth it.
kejj
Anyone tried the Stebel Nautilus Compact on a series 3(12v elec.)?
________________________
http://tv175.wordpress.com/
martinr
the DC the varitronic stator is only 7-8 volts ok to charge the battery but no good direct
Bilko
Main scooter: LI150
soulsurfer wrote:You really need 12v DC from a battery.
....and thanks to Byron, my Lambretta horn is great! :D
Bilko's Oily Blog
Bilko wrote:....and thanks to Byron, my Lambretta horn is great! :D
:mrgreen: cool. and your brake light works ;)
kejj
Care to give details on how it was solved?
dirtyhandslopez
A 6v a/c horn on 12v a/c always sounds pretty horny to me. Not like you have your finger on the horn button long, so chances of burning it out are low.
That's not going anywhere...
