ZIKES LAMBRETTA SERIES 2 TV175 FROM SWEDEN
Posted: Tue Feb 17, 2009 2:20 pm
RELOCATED AS REQ
Zikes wrote: Here it is after picking it up and dropping it off in my temporary garage (1000 km journey).
The mileage was low.
Some special solutions to it...
The carb is an old Bing with 2x18 throttles. It was originally featured on an old Swedish Husqvarna machine known as silver arrow. I will probably keep it. Simple and effective can't go wrong.
Nice checkered flags on it from the beginning.
Some stage in the dismantling of everything. It's currently in the shop for some blasting and varnishing. It will probably be a dark slate grey color and perhaps some clean pinstriping on it.
The engine on the loose. It was running perfectly so I will probably wait until next winter to renovate this.
I hope you'll like it.
Zikes wrote:Hi again,
So, updates on the progress. Actually there hasn't been much progress with the TV. Instead I decided to learn how to weld with a MIG. So I built myself a nice engine holder. Not perhaps the most useful tool but it will probably still come handy now and then.
Here it is in its red glory.
Before I painted it I put it up so that you could see how it works. Note that a M10 screw is holding the engine from below and at the top I've added some big washers so that it can still be used if I replace the engine mount rubber.
