Jetex Jets
Posted: Tue Jun 29, 2010 12:29 pm
by kejj
Hi all.
I'm looking to upgrade my jetex sh22 SOI-100 with some decent del'orto jets.
Problem is that I can only make out the small jet that's a 50.
The other 2 I cant make the figures out. The choke jet just has a 1 on it and the mainjet seems very long and only says 5.
My engine is a SIL GP200, I have a scootrs stainless steel exhaust.
What are the standard recommended jet sizes for this setup? Which equivalent Del'orto Jets match this carb?
Best
/K
Re: Jetex Jets
Posted: Tue Jun 29, 2010 1:09 pm
by bristolmod
main jet 123
Pilot 45
starter 50
Atomiser 5899/2
slide 7895/1
Re: Jetex Jets
Posted: Tue Jun 29, 2010 1:37 pm
by kejj
bristolmod wrote:main jet 123
Pilot 45
starter 50
Atomiser 5899/2
slide 7895/1
And the Delorto parts for hte SH2 carb fits and are interchangeable?
Re: Jetex Jets
Posted: Tue Jun 29, 2010 1:58 pm
by bristolmod
jets and atomiser certainly are. The slide should be although I've never had the need to substitute one
Re: Jetex Jets
Posted: Tue Jun 29, 2010 2:22 pm
by kejj
bristolmod wrote:jets and atomiser certainly are. The slide should be although I've never had the need to substitute one
GReat thanks, dunno why I should change the slide though. Got any reason for the suggestion?
Re: Jetex Jets
Posted: Tue Jun 29, 2010 9:35 pm
by Special X
Just change the jets, standard main is 118 but 123 sounds good with ScootRS pipe.
Re: Jetex Jets
Posted: Tue Jun 29, 2010 10:14 pm
by Doom Patrol
I'd really advise you not to change the slide. In my experience you can't mix and match slides or it will run poorly.
Re: Jetex Jets
Posted: Wed Jun 30, 2010 8:08 am
by kejj
Doom Patrol wrote:I'd really advise you not to change the slide. In my experience you can't mix and match slides or it will run poorly.
Cool, thanks 4 the tip.
