Ron Moss "AVANTI" exhaust
Soulpunk
anybody seen one live or tested them?
except a dyno-printout and the quoting that its not much louder than an af-clubman, i know not much about it. would like to order one but at this price-level i would like to get more infos on it..
Avanti 48mm Big Bore Exhaust
The all new Avanti large cone big bore,
-Slip joint on "U" tube ti Silencer.
-New internal design combined with other features enables higher RPM. See Dyno results.
-25mm O/D tail pipe.
-Each exhaust individually made and fitted to an engine before dispatch.
Price £250 Post & Packing £12.50
http://www.ronmossatsupertune.co.uk/
post removed.. :anbrgin;
Last edited by Muttley McLadd on Wed Apr 06, 2011 1:35 am, edited 1 time in total.
camel
im seeing them advertised on ebay at the mo thru ron moss,so they must be available
OAP
Hi,
I will ty & up date the ebay advert, & change photo's!
Dyno run was on a 200 barrel which can go up to 9K with a straight through system,
Indian Big Bore : max power 15.36 @ 8235rpm
42mm Clubman : " " 15.92 @ 7592rpm
Avanti " " 17.81 @ 8293rpm
You can always ask any questions by email [email protected]
or ring on 07951952768 9 - 6pm
I'm away from 2nd- 20th July
Ron M
CPH Lambretta
Main scooter: DL 150 1970
Hi Ron/OAP,
is that a picture of Beck in your Avatar? :D
Slow is the new fast!
adriang
wow, looks very interesting. Big bore a@48mm, are the loud?...
