ancillotti exhaust
woody69
:evil: got a ancillotti exhaust month ago,rideing bike to day all nuts holding exhaust on had come loose manifold ones gone exhaust clamp on the tail pipe snapped now kick statt is hitting tailed pipe when kicked of r these exhaust always as gd as this? :?
I don't think it's the exhaust's fault if the nuts came loose :-?
joey
...exhaust fitting is always a bit of an art...been lucky to have ralph saxilby clubman which is tailor made perfect fit....but i've recently fitted mk1 ancillotti.....tricks are to make sure it goes on/off without any straining of brackets....fit brass nuts + washers to u pipe....plain nuts spring washers to main bracket....if you've got the bracket underneath use a long 8mm bolt as a stud with plain 8mm nut/spring washer....blah...blah... :geek:
joey wrote:........tricks are to make sure it goes on/off without any straining of brackets....
QFT. i used an Ancillotti for 1700 miles with no issues, sold it on and it was used some more.
