rear brake
oggy
What oclock dose the rear brake arm have to be ,as my cable clamp is right in the shock casing and not twisting the brake cam before it hits the casing,sorry for being dense!!
move the arm back a couple of splines then.. :D
minotaur
and top tip , use one of knowledges cables.........
oggy
thanks,nearly finished,then i can show what you lot helped build.
The greatest leverage is when the brake arm is at 90 degrees to the cable. Make sure that when your brake is hard on it's as close to a right angle to the cable as possible and definatwely not more as you will loose efficiency
dirtyhandslopez
Time for new brake shoes?
That's not going anywhere...
