Page 10 of 76
Re: Ron Moss - Avanti TT3 - Cylinder Kit - Review & Test....
Posted: Thu Jan 19, 2012 9:53 am
by Special X
bigmuff wrote:This is not supposed to be inflammatory but had a good look at the Avanti TT3 kit yesterday in Allstyles. Not seen one before in the flesh and i was surprised (to put it lightly) at the finish on the exhaust port. If I had the £500 to get one I would have liked to have seen something finished a bit better. Stevie Wonder with a jackhammer springs to mind.
It's a "hidden flow feature" :mrgreen: Seriously though, the ones I've seen (2) were well finished and I'd love one.
Posted: Thu Jan 19, 2012 5:39 pm
by corrado
Special X wrote:
........ and I'd love one.
Could be my first sale at Wicksteed, or in the van on the way down there. :mrgreen:
Posted: Fri Jan 20, 2012 7:56 am
by Special X
Possibly . . . very possibly
Posted: Fri Jan 20, 2012 8:08 am
by soosh
Now I'm sure you said in a post about a year ago "39mm carb and box pipe...Nah!"
Posted: Sat Jan 21, 2012 8:16 am
by Special X
Certainly did. However I reckon they are definitely good for an ultra reliable relaxed touring 18bhp with a 30mm carb and box pipe, and thats brrrrrrilliant! Mucho cooling area as well.
PS I still say a 39mm carb and box pipe are not a marriage made in heaven. Go on Soosh tell me they go together "like peas and carrots" (Forest Gump 1994). :mrgreen:
Posted: Sat Jan 21, 2012 8:48 am
by Muttley McLadd
Posted: Sat Jan 21, 2012 10:06 am
by lamblast
any mpg figures yet ?
Posted: Sat Jan 21, 2012 9:24 pm
by wack 63
I fitted one of the Avanti kits today and was impressed with the fitting especially the ease of setting the squish.Innocenti casing,Ron advised the 1mm base gasket then measure the piston edge to top of cylinder which was 3.33mm minus 2mm head spigot=1.33mm clearance .Nice. I removed some of the casting flash in the ports and polished the exhaust port and hardly had to match the CDC inlet manifold. I thought the ring gap was a little tight at just under 0.20mm so opened them up to 0.25 although they may have been ok.One hole in the top of the head cowl needed opening up for the two M5 screws to fit without tension on the cowl but other than that it was a pleasure to do for a change.I then fitted a 20 t front sprocket but had to cut about 25mm off the lower tensioner which I believe Ron recommends leaving out but I like to use.All in all took nearly all day,talking included :roll: , but was a lot easier than other kits that need more fettling so it's now down to the owner to fit and modify his JL3 and get it run in although we're gonna get it on a dyno soon.
Posted: Sun Jan 22, 2012 1:26 am
by sideout
wack 63 wrote:.... it's now down to the owner to fit and modify his JL3 and get it run in although we're gonna get it on a dyno soon.
Thanks for the feedback Wack 63, why does the JL3 have to be modified?
Posted: Sun Jan 22, 2012 9:46 am
by CANbus
My cylinder was ground to make way for the hex heads on the JL mounting bracket.See the vertical fins.
Also the hex heads were turned to roughly half their thickness
