Page 63 of 76
Re: Ron Moss - Avanti TT3 - Cylinder Kit - Review & Test....
Posted: Tue Apr 14, 2015 10:05 pm
by Yanker
Simples: Try an AS266 atomizer and set your needle richer to start withm then lean out. Else get it dynoed.....
Posted: Tue Apr 14, 2015 10:48 pm
by eden
mick1 wrote:I ran my Avanti for 3 years, continuously fighting the low down bogginess, some modifications/adjustments worked better than others.......I've just fitted a Mikuni TMX 35 and I would suggest that is the solution. The bottom end difference is amazing, just hope the top end performs as well !!
Saying all that the other 2 Avantis that I ride with seem a lot cleaner at the bottom end than mine did, all very similar set-ups so who knows ?
are your mates running more advanced timing than you? more advance would clean up a boggy arse.
Posted: Wed Apr 15, 2015 6:56 am
by mick1
No they're both running static at 17 degree, I'm using a M-Tech set at 25 retarding to 16. The only main difference is the exhausts, i'm on a Franspeed Race, one lads got my old Franspeed Tourer and the other an old style DJ. Final drives are all 4.8 and until my change to the Mikuni we were all using 30mm PHBH's.
The DJ seemed the best all rounder, hardly ever changing gear and getting the best MPG.
The rider of the DJ had a go on mine with the new Mikuni and is very impressed........I think the Mikuni's will out number the Dellortos soon !!
Posted: Wed Apr 29, 2015 12:22 pm
by monkey boy
So the lads with super tourer pipes on their Avanti's ,what final drives are you running?
Posted: Wed Apr 29, 2015 12:52 pm
by Adam_Winstone
4.8
Posted: Wed Apr 29, 2015 4:06 pm
by paulnobodyimportant
Monkey Boy
I'm was running a similar set up as yours, but with a 225 Monza and JL3. I set up the jetting myself and Dan dynoed it and it was fine with no adjustment.
My setup
Ky Tronik ignition thingy, static timing at 26 degrees and on curve 8
30 mil phbh.
x7 needle on top setting,
50 pilot,
Av266,
70 choke
50 slide,
Ran like a dream with no richness.
Just had the Monza barrel slightly tuned and fitted a Franspeed touring pipe and its really boggy from 1/4 to 1/2. But from O to 1/4 and after 1/2 runs great. So after advice from this forum and searching myself, it is too dangerous to go down to a AV264 atomizer. So after a bit of research, I've just ordered a leaner AS266 atomizer, as suggested above and see if that gets rid of my problem. he AS266 is a leaner atomizer than the AV, so I will see if I can lean out that boggy zone but will let you know. T
Plus as Nelson PK states, round slide carbs, like the PHBH, have vortex flow (all over the place) around the slide at low revs, which makes it difficult to set up on lower revs. However, the Mikuni has a flat side and doesn't have the same problems. I have both types of carb, (Mikuni on a TS1) and do feel that the Mikuni is easier to set up and has great throttle response. Down side is that the fixed atomizer wears and means that you have to play around with thicker needles.
Posted: Wed Apr 29, 2015 6:49 pm
by monkey boy
Thanks for all the help lads I really appreciate it.
Posted: Wed Apr 29, 2015 6:51 pm
by monkey boy
Gonna rinse what I can from the Phbh and when I reach a point where I think there's nothing more I can do I'm gonna chop over to a 35 Tmx.
Posted: Mon May 04, 2015 10:12 pm
by Rick
I see Adam in running 4.8 with a super tourer... I'm running 4.6 which seems ok on long runs and motorways but is abit much for every day use... What are other using?
Posted: Mon May 04, 2015 11:25 pm
by coaster
I'm on 4.8 with a Super Tourer and 30 PHBH. Has anyone tried a 30 PWK on an Avanti ? I have a spare one an just about every jet and needle known to man so I'm tempted to try it. My main concern though is the small float bowl which can drain if the level isn't spot on. I just took delivery of a clear float bowl which I was thinking I could use to check the level is right.
