Page 7 of 8
Re: LAMBRETTA DYNO GRAPH POSTING AREA
Posted: Sat Jan 12, 2013 11:59 pm
by SouthamptonSaint
Old school Suzuki 205 by Chiselspeed.
Posted: Mon May 13, 2013 11:11 am
by tonydevon
his is the last in 3 runs/setups that were done with my standard mugello kit, tested with 28 and 26mm dellorto carbs
ended up with the 26mm, PM expansion chamber, open carb, 17 degrees fixed timing.
feels very good on the road but desperate to get it tuned/ported later this year as I need more go :)
the TQ figure in the text at the bottom must be some sort of glitch LOL
Posted: Mon May 23, 2016 6:00 pm
by wack 63
Image Anyone care to comment on the initial weakness at low revs? Raising the needle and pilot separately made the motor run too rich. Rapido 204.
Posted: Mon May 23, 2016 8:45 pm
by drunkmunkey6969
Did you try a bigger atomiser? What's the full setup?
Posted: Mon May 23, 2016 9:19 pm
by wack 63
It's a VHSB 38,55 idle, 160 main but will have to check atomiser and needle/ slide
Posted: Sat Jul 15, 2017 9:55 am
by Major Hassle
225 TS1 27Bhp 23ft lbs Torque, cyclone 5, tmx 35 mil, franspeed tourer
Posted: Sat Jul 15, 2017 10:44 am
by Major Hassle
Major Hassle wrote: ↑Sat Jul 15, 2017 9:55 am 225 TS1 27Bhp 23ft lbs Torque, cyclone 5, tmx 35 mil, franspeed super tourer
Posted: Tue Apr 26, 2022 8:49 am
by Fruitjuice
Monza '240'
Barrel bored to 71mm with an H2 Wiseco piston
Touring tune by Powolotti
TMX30 carb
Short inlet manifold
60/116 crank
Adspeed ADS3 exhaust
16/46 with an Indian GP200 gearbox
LTH 7-plate clutch with uprated springs
Posted: Wed May 04, 2022 7:14 pm
by drunkmunkey6969
Fruitjuice wrote:Monza '240'
TMX30 carb
60/116 crank
I can’t read those graphs, but knowing Powolotti tuned it, I’m expecting a good power output. What’s the result?
Posted: Thu May 05, 2022 7:40 pm
by Fruitjuice
29.5hp @ 6300rpm
33.7Nm @ 5900rpm
above 20hp from 5200 rpm up to 7500 rpm
above 20Nm from 4800 rpm up to 7400 rpm
