Re: Not quite what was expected!!!!
Posted: Mon Aug 15, 2011 12:10 am
well here is the latest update on this,...and i,m still not happy with it cos although ive stripped it ,and rebuilt it with porting its still not perfect yet I,m afraid. So i,m gonna strip it again ..
the good news is that its now getting approx 23/24 bhp after porting the cases to match the barrel,I also modified the piston holes /cut outs to give more area and flow as recomended by malossi/sip ...
I didnt touch the crankshaft in this case but did give it 360 degrees intake by cutting a tunnel port from the intake to the barrel ..over and above the crankshaft ...as can be seen on previous reed valve tunes that i have done and as shown on the "scooterotica"tuning pages ..
3 or 4 bhp increase in power may not sound like a lot for the time and effort required ,but in % terms its equates to approx a 20% gain over a 20 bhp motor which aint too bad me thinks ... :lol
and the reason why i,m stripping it yet again ? ..well ,although ive cured the kick start lever stripping prob ..its still not returning up properly ..and also the freaking bronze clutch bush decided to weld itself to the clutch pressure pad (which i have never seen before lol)..oh and one more thing ..the rear hub still feels loose on the axle splines ...so much so that even after replacing the rear axle bearing ...its never gonna pass an mot
,so going to have to put in another shaft ...what an arse hey
