Re: Ron Moss - Avanti TT3 - Cylinder Kit - Review & Test....
Posted: Thu Nov 07, 2013 2:20 pm
So are you saying you can just bolt a reed block on and expect an improvement without any mods to ports or piston?
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
faf wrote:So are you saying you can just bolt a reed block on and expect an improvement without any mods to ports or piston?
I think a finger port running up from the inlet to the transfers will be needed as well but would be happy to hear other views on this requirement. Loss of top end performance would my main worry.psychedelicropcircle wrote:faf wrote:So are you saying you can just bolt a reed block on and expect an improvement without any mods to ports or piston?
You'll need to cut a half moon or window in your piston and trim the fins on the barrell. Other than that well yes. My main reason was to eliminate the spitback . It'll improve it slightly at the bottom.
There's the wrap around boost/trans port above the inlet on the Avanti.....coaster wrote:I think a finger port running up from the inlet to the transfers will be needed as well but would be happy to hear other views on this requirement. Loss of top end performance would my main worry.psychedelicropcircle wrote:faf wrote:So are you saying you can just bolt a reed block on and expect an improvement without any mods to ports or piston?
Running a boost port up the back wall isn't as straight forward as on other cylindersfaf wrote:Which means............??????
Jazzy, i've just offered my nk road ts1 stub up to the Avanti and it's way out on the studs. Is there a TT3 stub available seperately?Jazzy wrote:running a nk road 4.6 on li 150
30 mm dely, would love to try a 34mm delly or amal
