Page 53 of 76
Re: Ron Moss - Avanti TT3 - Cylinder Kit - Review & Test....
Posted: Sat Jul 13, 2013 2:59 pm
by mick1
Out of interest is the quality of fuel the same in the US as we have over here in the UK ? ......(i bet it's a dam site cheaper
Posted: Sat Jul 13, 2013 7:42 pm
by gp200ts1
I know that regular is 87 octane rating but they calculate octane ratings differently in the states to over here, something to do with ron and mon rating
Posted: Sat Jul 13, 2013 8:48 pm
by OAP
Look I get the blame for a lot of things already but I do NOT grade kin petrol, leave my name out of it
Posted: Sat Jul 13, 2013 8:49 pm
by Tom Russell
OAP wrote:Look I get the blame for a lot of things already but I do NOT grade kin petrol, leave my name out of it
Lol
Posted: Sat Jul 13, 2013 10:16 pm
by paul190
Although petrol is slightly lower in octane in USA it does have far more corn based crap in it.
Which fouls up spark plugs and burns really Inefficiently giving us really low gas miles and hours of fun cleaning carbs and replacing float bowls,because the ethanol makes them expand and float bowl needles because the same crap eats away at the rubber tips , if you have that type .
Posted: Sun Jul 14, 2013 8:01 am
by mick1
So your jetting would probably be different on UK fuel..........
Posted: Thu Aug 01, 2013 4:01 pm
by paul190
right now mikuni carb set up for my Avanti is
6en11-58 needle second clip
290 main jet
15 pilot
also recently installed the jockeys boxenstop rear brake kit ....VERY NICE
feels really solid. can really brake now !!
Posted: Thu Aug 01, 2013 4:40 pm
by victor
paul190 wrote:Although petrol is slightly lower in octane in USA it does have far more corn based crap in it.
It's not the ethanol in modern fuel that is causing this but all the other additives fuel companies add to clean fuel injectors, increase efficiency and make the fuel mixable with ethanol, among other things. Alcohol is much less aggressive on plastic and rubber than petroleum based fluids.
Posted: Fri Aug 02, 2013 6:34 pm
by GP240
so which should I now use ?
2 star or 3 star haha.
I can see your point about the fuel cleaning the injectors and this is probably the cause to rubber breaking down and floats swelling (depre-fekin-dation lol), but being a minority in the "OIL INDUSTRY" what's the option/solution.
Posted: Fri Aug 02, 2013 9:26 pm
by victor
As long as you up jet slightly with increasing ethanol mixture (as it's a bit leaner) you will be fine. A friend of mine (researcher/chemist and nerd) is running 100% ethanol just to test if it's possible and to be environmentally friendly and mentioned upjetting 140% was necessary but I think he said you'll need special oil to allow it to mix with alcohol.
Remember, you can easily put alcohol in you cars windscreen washing fluid container with no ill effect to the system, try putting petrol in it and it will ruin all the tubes
Problem is rather that people run poorly setup carbs with the original 60s type of float needles and floats. My SS carb leaked like crazy, fitted modern float and float needle and problem solved
