Re: Center stand
Posted: Tue Mar 29, 2011 8:25 pm
Got down to the garage to take measurements, forgot the note I wrote everything up on but I did some experiments.
The stand was fitted with my old splash-plate including J hooks. It must be bent cause on the left side the stand is not tight to the cross-member:
Compare:
And the whole stand is off the ground by a good bit:
And on popular request, my tires:
The old stand is home brewed and too long so it got bended. My new one is short of 2" max:
So I experimented, I fitted the stand to my original TV175 S3. The stand is still 1-2" short and the MB J shaped brackets are still so tight the stand wouldn't even go on:
As far as I could get:
I fitted the MB stand with the splash plate that has the J hooks welded on and that way the stand aligned correctly, also used the stand support brackets.
I must say I am very amassed of the poor measurements on a MB product that costs 3 times the competitors. Guess I am paying for zero better fit but for steel quality.
Tomorow I will pick up the measurements note.
Compare:
