Page 5 of 8
Re: LAMBRETTA DYNO GRAPH POSTING AREA
Posted: Thu Jan 05, 2012 12:15 am
by Diablo
Ok heres a graph to show just how good the V4 186 Muggys are now. Chris Sturgess built this for one of our customers. It went in a Chop that I loved but had minimal brakes! Anyway I think 19.3 and 16ft/lbs of torque is pretty good out of an unfettled kit. Not the same area under the curve as big block kits but good none the less.
The kits are good but some messing about to get port timings how we wanted them and ended up running a head gasket despite the recessed head.
One thing to note here is that to match the crankcase to the transfers and leave a decent gasket face the case was welded and then refaced to give more meat for flowing. The barrel was unported and ran a 28mm PHBH and a PM pipe. The carb was rich for running in. Jets were:
118mj
AV268
X13T1
55 pilot
40 slide
Bellmouth(In this case made the midrange better at the expense of rev on)
Power on the left torque on the right.
Posted: Tue Jan 17, 2012 9:34 pm
by Powolotti
graphs of a std. unfettled TS1 with JL road vs. a Powolotti road tune TS1 with Franspeed race. Shows the dyno is not throwing fantasy figures
Posted: Wed Feb 22, 2012 2:07 am
by Darrell Taylor
TS1 225 + 60MM STROKE CRANK 30MM CARB PM MAMBA PIPE
31.31 BHP 21.48 TORQUE
been wanting to do a torquey 30+ bhp 21+ torque set up on a 30mm carb for a while now and was sure the other ts1,s ive done would do it but never got round to trying a 30 on them i was dissapointed at first with the result but then found the reasons why,the importance of good set up dimensions is shown here the below graph shows red before and blue after
the ts1 i tuned was fitted with a 58 crank that has just been upgraded to a 60mm bgm crank and packer the red is how it arrived with the cylinder assembled to the wrong durations and the blue is after i stripped it down and rejuggled the packers to achieve the best durations as close to my original design that the stroker crank would give me
torque up from 19 to 21.5
power up from 28 to 31.3
no other changes were made between tests
Posted: Wed Feb 22, 2012 2:13 am
by Darrell Taylor
old MUGELLO 186 20.41bhp
ive tuned JL4 SPACO 28 (no rpm trace on this one so power v speed in 3rd gear)
another low port timing/smaller carb tune that pulls from really low rpm with a wide spread
its the early mugello without a boost port
Posted: Sun Mar 11, 2012 11:50 am
by Darrell Taylor
RB225 WITH 60MM STROKE 33.73 BHP 22.5 TORQUE
One ive tuned thats on a fresh replate in need of running in
35mm mikuni / ads pipe / low comp head / straight line ign
a compression increase and an ign curve would make it 35+
prior to the tune was 25.3bhp
33.73 BHP shown in power v speed
Posted: Fri Mar 30, 2012 11:16 am
by Darrell Taylor
RB225 WITH 60MM STROKE CRANK 35 BHP 25 TORQUE
one ive tuned cyl and cases / 35mm mikuni / franspeed / straight line ign /low comp head
this motors graph was shown before with different pipe and shown in power v speed
now with new pipe and power v rpm
this is the motor used in the road legal silver lamby at mallorry track day ,it completed all the sessions and despite having sprint rack/centre stand/kick start/legshield tool box/basic suspension and brakes/all steel body ,very limited lean angles as ground out on pipe and centre stand with a non racer onboard managed a best lap of 1min 18 only 6 secs adrift of the quick regulars on the day
34.94bhp 25.33 torque
Posted: Fri Mar 30, 2012 11:33 am
by Darrell Taylor
TS1225 WITH 60MM STROKE CRANK 32.64BHP 21.92 TORQUE
ONE IVE TUNED CYLINDER/HEAD , 30MM CARB, VF3, FRANSPEED,STD IGNITION AND FLYWHEEL
RUNNING A BR10ES SPARK PLUG THAT I FITTED 2 AND A HALF YEARS AGO
32.64 BHP 21.92 TORQUE
Posted: Wed Apr 11, 2012 12:28 am
by Darrell Taylor
thanks Stevo
Rapido 225 std 58 stroke 20.84bhp
one ive done a mild tune on for 2 up touring use with standard looks
runs a 30mm dellorto on af inlet and a clubman exhaust
owner is delighted with results and has found he,s keeping up with ts1,s with ease
ive recommended the mb clubman as soon as there ready which might get it up to 24+
20.84bhp
Posted: Fri Apr 20, 2012 7:37 am
by clash1
monza 200 out of the box, jl3, tmx 30
Posted: Wed May 02, 2012 11:58 pm
by TS1-200
TS1 230 60mm crank, Yam rod, head dowelled, recessed,and profiled to match racetour piston, 34mm Delly, NK pipe, no tuning apart from small amount of work to exhaust port by Ian. 25.9 bhp, 19.2 lb. ft. torque
