OK, sorry for the delay (nothing compared to Adspeeds wait for graphs!! lol) but have been busy.
Anyway, built scooter Saturday and dynoed Monday, it was a VERY gentle run as it was a brand new kit and not yet run in or ready to be thrashed, so the figures are not to be considered peak yet. Also, as a cautionary point, it was jetted quite rich for safety so again, not peak figures. And lastly.....Andys clutch started slipping, he did say it was well worn and i suspect the increased power of the Avanti kit exposed that weakness. Sounds like a list of excuses, but its just the way it was on the day. So we didn't bother doing all 3 pipes we had to hand, just the PM pipe his scooter came with.
The clutch will be getting changed next week when we the bits arrive, and we are going to fit an MB upgraded gear selector spring at the same time, i will then re-dyno with all 3 pipes. We also hopefully have Corrado dropping off a selection of additional pipes to try too (including a clubman).
Anyway, for now, here is the result with the PM pipe, rich jetting and slipping clutch:
What you see above are three BHP curves, the purple is the Avanti TT3 kit, and i also picked two other scooters that we have previously dynoed for comparison. As stated before, the Avanti kit is fitted with PM pipe, 30mm Delly and unported/standard casings, therefore i picked 2 other scooters with 30mm dellorto carbs and unported casings to compare. The Blue line is a 200cc SIL standard cylinder with 30mm delly and a ScootRS pipe (PM copy). The Green is an unported/standard TS1 225 with 30mm delly and Devtour.
Now as you can see, the SIL200 is predictably the lowest performer, hitting 12bhp by 6000rpm and holding on until 7500rpm, the running out of steam. The TS1 is performing in the power over a similar rev range, but up at 18bhp. And the Avanti is right up there with the TS1 peaking at 17.5bhp but also pulling very strongly in the mid-range too.
Now given that the two other kits were run in, had no clutch slip and were on their final jetting run, i think the Avanti is showing great promise at this early stage. Also, on a previous test we did on Andy's stage 4 tuned engine, we know the Franspeed Race pulled 2.5bhp more than his PM pipe so just a straight change of pipe on the Avanti should take the readings on our dyno to 20bhp, but we expect more than that once the slipping clutch is changed and the jetting is corrected.
That's all for now, more to follow.....
