Page 33 of 76
Re: Ron Moss - Avanti TT3 - Cylinder Kit - Review & Test....
Posted: Sun Apr 29, 2012 3:12 pm
by soosh
Adam_Winstone wrote:
sideout wrote:
Adam_Winstone wrote:Mine's still being used daily and is running well. Sadly, because it is being used daily I've not actually messed around with it as much as I'd have like to (trying out various configurations). Thankfully, it's doing exactly what it says on the tin so leaving it alone is probably doing me a favour ;)
Adam
Is yours run in yet Adam?
Nigel
Yep, sure is and gets given some stick too :D
And i hope your not running girly fully synthetic but our finest horticulture? ;)
Posted: Sun Apr 29, 2012 6:00 pm
by Adam_Winstone
"And i hope your not running girly fully synthetic but our finest horticulture?"
What do you think, knowing that my wallet is tighter than my bore?!
Adam
Posted: Sun Apr 29, 2012 7:29 pm
by sean brady scooters
Adam_Winstone wrote:"And i hope your not running girly fully synthetic but our finest horticulture?"
Adam
wish I had 3 thou in my wallet lol
Posted: Sat May 05, 2012 10:34 am
by coaster
coaster wrote:Well, got past the 200 mile mark this afternoon so pushed it up to 50-55mph and my god what a difference. I thought it was torquey at 45 but 50-55 is where the power starts to kick in with my 4.7:1 JL3 set up. After about 20 miles on B roads going up to 55 mph for prolonged spells my clutch started showing signs of distress, I always knew that my 4 plate setup would need upgrading :oops:
Update: I spent a few hours last night installing a 5 plate clutch, I used advice from Diablo on another clutch related thread and mixed and matched plates and steels until I had between 1mm and 1.5mm clearance between the top plate and the friction disc. Just took it out for a 10 mile circuit and couldn't get it to slip at all, accelerated up to 67 in top going up long hill (only for a few seconds Ron ;) ) and it was fine...cheers Al 8-)
Posted: Sat May 05, 2012 11:44 am
by sideout
coaster wrote:.... Update: I spent a few hours last night installing a 5 plate clutch, I used advice from Diablo on another clutch related thread and mixed and matched plates and steels until I had between 1mm and 1.5mm clearance between the top plate and the friction disc. Just took it out for a 10 mile circuit and couldn't get it to slip at all, accelerated up to 67 in top going up long hill (only for a few seconds Ron ;) ) and it was fine...cheers Al 8-)
That's good news Colin. Did the clutch lever need much more effort to operate it, I think you said you were using MB uprated springs?
Posted: Sat May 05, 2012 12:29 pm
by soulsurfer
What other components were used for this clutch Col?
Posted: Sat May 05, 2012 1:21 pm
by Adam_Winstone
"wish I had 3 thou in my wallet lol", of an inch or Lire... :)
Posted: Sat May 05, 2012 3:02 pm
by coaster
sideout wrote:
coaster wrote:.... That's good news Colin. Did the clutch lever need much more effort to operate it, I think you said you were using MB uprated springs?
Hi Adam, no, the clutch is very light and feels exactly the same as it did before with the Taffspeed springs in it. I do have an MB Yam type dogleg lever though which helps. It could do with a little more 'stroke' (travel) as it drags slightly (I could live with it though) so I might use Mark's idea of cutting 10mm out of the clutch arm.
The selection of plates I ended up with was 4 x Camlam thin Surflex plates (2.5mm) plus one standard plate (3.5mm), 4 x 1mm steels and one standard steel (1.5mm) with a thick (3.5mm) top plate. All other parts are standard Indian.
Posted: Mon May 07, 2012 4:50 pm
by psychedelicropcircle
1st miles today a wee 10 mile circuit round Edinburgh....engine proper tight...needs some cable adjustment...no panels on and my left ankle is perfumed thanks to the carb..... :freak:
Posted: Mon May 28, 2012 4:25 pm
Thats the avanti ran in now this time last week id done 50miles. a couple of hundres local miles through the week with a 500 mile trip into the highlands..
have to say how much less vibration the avanti has, i was driving without gloves wot with the weather being so nice normally youd have white finger and buzzed hands..on a lesser note if it gets out its preffered rev range you find yourself knocking down a couple of cogs (li150 46 16) but all in all a fast tourer.
p.s sorry for the veshpers :ninja:
