Page 4 of 6
Re: Spluttered. Won't rev
Posted: Tue Jul 08, 2014 11:43 pm
by rosscla
Sounds like a similar problem foremanbob had recently turned out to be the stator
http://scooterotica.org/forum/viewtopic.php?f=7&t=31436
Posted: Tue Jul 08, 2014 11:48 pm
by coaster
Bilko wrote:I use one of Darrell's chokes Colin, but I have checked. It started perfectly and ran perfect til I got 100 yards down the road.
So do I, it needed a right angle bend to get it to enter the carb and is close to the bottom of the tool box. Suspension movement makes it contact the bottom of the toolbox and over time (Davos and back) it worked the choke retaining screw loose resulting in the choke sticking partially on.
Posted: Wed Jul 09, 2014 10:24 am
by dapper
Rob, you haven't mentioned whether it's piston ported or reed valve. Only saying 'cus it could be reeds loose or worn. Had a mate had this and it would start but not rev and a lot of spitback out of carb. If it's not reed valved then tell me to feck off
Posted: Wed Jul 09, 2014 11:48 am
by Bilko
Thanks lads.
Stator change, petrol change and then engine inspection will be the order of the day today.
Posted: Wed Jul 09, 2014 8:16 pm
by Bilko
Changed the stator, changed the petrol. Wants to start, but nothing.
Posted: Wed Jul 09, 2014 8:29 pm
by Mark ULC
Read over the posts Bilko and it seems you have changed all electrical and the main fuel checks. Is the plug wet? Anyone handy to switch over carbs? Frustrating but keep going. Hopefully someone can give more advice.
Posted: Wed Jul 09, 2014 8:31 pm
by mick1
hmmmm.......stuck or broken ring ?
Think your into the heart of the engine now, looks like it's not air or fuel
Posted: Wed Jul 09, 2014 8:39 pm
by Bilko
Changed carbs over. Plug wet.
Top end off tomorrow.
Posted: Wed Jul 09, 2014 8:41 pm
by Bilko
I'll make a start tonight.
Posted: Thu Jul 10, 2014 12:23 am
by Bilko
First thing to see. Took the exhaust off and a load of oily petrol came out.
Would that have been carb trouble flooding the engine?
