Spluttered. Won't rev
Sounds like a similar problem foremanbob had recently turned out to be the stator
http://scooterotica.org/forum/viewtopic.php?f=7&t=31436
Bilko wrote:I use one of Darrell's chokes Colin, but I have checked. It started perfectly and ran perfect til I got 100 yards down the road.
So do I, it needed a right angle bend to get it to enter the carb and is close to the bottom of the tool box. Suspension movement makes it contact the bottom of the toolbox and over time (Davos and back) it worked the choke retaining screw loose resulting in the choke sticking partially on.
dapper
Rob, you haven't mentioned whether it's piston ported or reed valve. Only saying 'cus it could be reeds loose or worn. Had a mate had this and it would start but not rev and a lot of spitback out of carb. If it's not reed valved then tell me to feck off :shock: :lol:
Bilko
Main scooter: LI150
Thanks lads.
Stator change, petrol change and then engine inspection will be the order of the day today.
Bilko's Oily Blog
Bilko
Main scooter: LI150
Changed the stator, changed the petrol. Wants to start, but nothing.
Bilko's Oily Blog
Mark ULC
Main scooter: LI Series 2
Read over the posts Bilko and it seems you have changed all electrical and the main fuel checks. Is the plug wet? Anyone handy to switch over carbs? Frustrating but keep going. Hopefully someone can give more advice.
mick1
Main scooter: Li Avanti 225
hmmmm.......stuck or broken ring ?
Think your into the heart of the engine now, looks like it's not air or fuel :(
Bilko
Main scooter: LI150
Changed carbs over. Plug wet.
Top end off tomorrow.
Bilko's Oily Blog
Bilko
Main scooter: LI150
I'll make a start tonight.
Bilko's Oily Blog
Bilko
Main scooter: LI150
First thing to see. Took the exhaust off and a load of oily petrol came out.
Would that have been carb trouble flooding the engine?
Bilko's Oily Blog
    Users browsing this forum: Semrush [Bot] and 9 guests
