Dragging clutch / weird scraping / petrol in gearbox oil
mushroom
Main scooter: Motovespa P200E
ah ok , so it'll be in my new complete clutch then ?
Could this be why the clutch started dragging ?
bazman
Yeah i would hope so fella!!
As for causing dragging etc by the sounds of it your old clutch had been through the wars so to speak lol.
It wouldn't have helped but not the sole cause methinks!
mushroom
bazman wrote:Yeah i would hope so fella!!
:lol:
Cruciform was a bit rounded too :)
goldeneye
the end of your layshaft looks a bit fooked as well, MK1 gearboxes only shim from one end, and the other end looks nakered. i"d replace that as well, or you"ll have gear jumpin problems from the off. i"ll rake in the shed for one for you. that one looks goosed.
mushroom
Pulled the old clutch apart and the brass shim was looking a bit sketchy
mushroom
Had to change every bearing in both case halves in the end as the brass bits were everywhere :cry:
