Rich, I've been following this thread for ages and like others have watched Eden 's vids thinking that his scoot is just what I'd like from a rally going motor.This thread has undoubtedly brought much good press to the GT kit(and so it should),but I also think that many buyers would be purchasing hoping to get what they see in Edens vids,I think if you could offer a package based on the build for that motor that will deliver the performance of that engine then you wont be able to make it quick enough to keep up with sales.I fully except the difficulties that you have put forward in your previous post as regards commercial viability etc and I am sure that you have studied the market for the type of product you offer(i.e a fast reliable rally going engine)and see that there are some serious costs attached to other engine packages out there.Is this something you might consider after doing the figures? I'm sure lots of people would love to have one.
cheers Jeff
GT big block experiance : New GT crank info added
Swat
- registered user
- Main scooter: AF Rayspeed S type GP225
- Contact:
I too, have been following Eden's posts (& associated video's) with great interest. Primarily just for entertainment allied to an inteest in the gamma technology speedo/rev counter unit - which I've now bought.
I'm hugely impressed with the apparent breadth of performance, wide rev range of meaningful thrust, 3rd gear overtaking ability, & capability of running tall gearing meaning high sustained speeds.
I don't know Rich T so have no vested interest in promotion thereof - but he deserves great credit on producing such an impressive (and it appears reliable) setup. My bike is an S type and for originality I've stuck with AF & run 225 rapido - - I know very little other than snippets from this thread but.. where a change necessary I'd be sorely tempted to investigate this kit
- Toddy
- registered user
- Main scooter: Lambretta Series 1
- Contact:
Swat wrote:I too, have been following Eden's posts (& associated video's) with great interest. Primarily just for entertainment allied to an inteest in the gamma technology speedo/rev counter unit - which I've now bought.
Rich , ill let you have a go on mine when i get it built
- Burnside
- registered user
- Main scooter: Lambretta TV200
- Contact:
I'm running the GT kit in my S-type with the 30mm carb and a BGM clubman, Li150 gearbox 17/46 (4.6 overall ratio). Regularly take it up to 70-75 mph on the motorways and it is also more than happy pottering around town. Can't recommend it highly enough, great kitSwat wrote:I too, have been following Eden's posts (& associated video's) with great interest. Primarily just for entertainment allied to an inteest in the gamma technology speedo/rev counter unit - which I've now bought.
your motor wont be slow though Toddy, ive tickled the ports a touchToddy wrote:Swat wrote:I too, have been following Eden's posts (& associated video's) with great interest. Primarily just for entertainment allied to an inteest in the gamma technology speedo/rev counter unit - which I've now bought.
Rich , ill let you have a go on mine when i get it builtOk Eden i am slow
over the winter im building a 250 using a GT barrel, Im building this one out of all good components rather than s**t I found behind the cupboards in the garage.
Engine case.... sorted
new crank...... sorted
barrel... sorted I think
piston... sorted
chaincase components... sorted
ignition....sorted
Just need bearings, seals, pipe, carb and the odd other parts.
currently i'm thinking i'll leave the GT230 as it is, I may not even do a winter rebuild on it.
- Rich_T
- Dealer
- Main scooter: Li Special
- Contact:
If I split the machining processes it would double all the set up costs and lose the economies of scale on ALL kits provided. This means not just an expensive option for 225 (that would be a very expensive Wossner piston too) but also the 200 kit. It effectively knobbles the commercials on both kits, this is why it will not be done.1469leach wrote: if you could offer a package based on the build for that motor that will deliver the performance of that engine then you wont be able to make it quick enough to keep up with sales.I fully except the difficulties that you have put forward in your previous post as regards commercial viability etc and I am sure that you have studied the market for the type of product you offer(i.e a fast reliable rally going engine)and see that there are some serious costs attached to other engine packages out there.Is this something you might consider after doing the figures? I'm sure lots of people would love to have one.
cheers Jeff
You can absolutely have a kit just like Eden's. To get one please contact Eden, send your casing and he'll build you one, simples. If Eden buys 100 kits each year then I'd look at it again (as that would make it a market reality) but, as I mentioned earlier this is a perception, it is not a proven reality. In fact, the reality is currently the opposite as I mentioned before.
The GT200 kit is the reliable base starting point but it has all the features and potential for exploitation (the Scootering article covers it all very well) so you have the opportunity of straight "bolt on" or tweak the performance either yourself or via a tuner. What I do help with is sharing the information and providing some manufactured parts to ease the process where possible. If you want a customised 225 then it needs to go to the cast iron specialists like Eden, Chris Sturgis, Darrell Taylor etc. There are quite a few more dealers selling GT kits these days so ask about too.
Porting another GT barrel tomorrow for my self
250cc this time, should be interesting
Went today to get the lathe work done as I don't have a lathe.
barrel bored, head profiled, crank built up. Thanks Ralph
............... using 62 * 116 with 71mm wossner H2 piston.
The new 250 is nearly ready to go into the frame, just need a few niggley bits.
trench in case for the 62mm stroke
mag marked up....
mag cut
case trans cut
Exhaust port cut, marking up for boost cutting can also just be seen.
Exhaust port finished.
Piston marked up
Arc cut
Window cut
Transfers lowered and boost lifted
Marking TDC and various degrees before TDC
Gears and sprockets in
That was Monday to Friday evenings last week. Tonight ive fitted the clutch, put all the studs in the case and fitted the brakes.
Could have finished it tonight but I need an 8mm case stud and gearbox oil.
Bore and head profiling was done by Ralph, I've done the rest.
Running 62/116 crank
Wossner H2 piston
Cant wait to get it running
mag marked up....
mag cut
case trans cut
Piston marked up
Arc cut
Window cut
Wossner H2 piston
