Page 3 of 3
Re: LTH clutch.
Posted: Fri Nov 06, 2015 10:53 pm
by 10 inch Terror
gerryjunior wrote:my clutch was stiff at first, its gotten softer after 1500 miles,
Has it got much lighter on the hand? I've only "dry" built mine i.e it's got no oil in the casing and without having the motor running. I'm hoping with oil in the case and the motor running it'll lighten up. I hope so as its way heavier than my AF Race clutch.
Re: LTH clutch.
Posted: Sat Nov 07, 2015 12:52 am
by corrado
I use LTH and AF road and both are no harder than the standard 4 plates I'd previously used. I found the BGM clutch cable to be the smoothest I've used. Check cable routing from exit of cable block, I've noticed some badly designed ones where the cable is rubbing on the adjuster, and one was an expensive one.
Re: LTH clutch.
Posted: Sat Nov 07, 2015 11:09 am
by gerryjunior
its gotten softer , but not one finger as the original ad when i bought it, i have a 5 plate reedspeed with mb springs and the lth is about the same as that, not nearly as soft as a standard 4 plate though.
