Rev Counter Wiring
Bilko
Main scooter: LI150
Balls. Well, you've saved me a load of headaches.
Bilko's Oily Blog
soulsurfer wrote:Thanks Byron.
How are they calibrated, can they be recalibrated to suit a different scale on a different face?
there is a variable resistor inside that can be used to fine tune it, maybe just the sensitivity in fact?
but I was planning to use a mechanical tach on the flywheel and see how accurate it was, then [most likely] end up making a new face with numbers in the appropriate places.
soulsurfer wrote:What diameter are they?
about 90mm face. Kawasaki KDX [another 2-stroke single with electronic tacho] are smaller
