Page 3 of 6
Re: Spluttered. Won't rev
Posted: Mon Jul 07, 2014 8:24 pm
by Bilko
Tried 2 floats John, both seemed fine.
Posted: Mon Jul 07, 2014 10:23 pm
by blue
Have you tried fresh fuel?
Posted: Mon Jul 07, 2014 10:55 pm
by Bilko
Hello mate, how's it going?
Haven't changed the petrol yet, but it's all I can think of trying so I'll give that a go.
Posted: Tue Jul 08, 2014 5:43 pm
by wack 63
What sort of carb is it?
Posted: Tue Jul 08, 2014 6:32 pm
by Bilko
Two different 30mm dellortos.
I'm trying to ake a connection with why it happened so quickly. It had been running perfectly, crisp and clean. I start it up, second kick revs perfect then 50 yards on it dropped to a splutter in an instant and it hasn't run since. It tries to start and I get an occasional 2 send rev then it dies.
Posted: Tue Jul 08, 2014 6:48 pm
by mick1
Think a pressure test might be in order......could be seals or head......or quite a few other things :roll:
Posted: Tue Jul 08, 2014 7:21 pm
by bazman
I'm thinking more of an electrical issue here possibly low tension coil. Even if you have acceptable readings on stator mate , they can still fail, what make is it ?
Worth banging a spare known good one on to try?
Posted: Tue Jul 08, 2014 8:14 pm
by Bilko
Hope not Mick, but it's heading that way..
Baz, just talking with a mate at the minute about this and the spare stator will get thrown on next to see.
Posted: Tue Jul 08, 2014 9:00 pm
by Mark ULC
Bilko I too think it may the stator breaking down. Had the same issue earlier this year, it would start occasionally for a few seconds then cut straight out. Changed everything then finally the stator and sorted. I think the LT can read ok with meter but when running can drop away. I did notice the spark was poor before the new stator was it. Good luck.
Re: Spluttered. Won't revx
Posted: Tue Jul 08, 2014 11:08 pm
by Bilko
Hello Mark. How's it going?
I'll definitely be getting the spare stator on
