Piston woes....
stew
Main scooter: Series 1 and series 2
Special X wrote:
Then rag the X7 needle out and throw it away (as they have a weak spot right in the area you seized
Is that not a bit of a generalisation? There must be
100's of Lammy's running on an x7 needle or have I missed something?
Stew
Loud pipes save lives!!
nelson pk
In my experience X7 needles are too weak for most mid range set ups but every bike is different but it would not be my first choice of needle.
Could be a combination of a little bit lean in the mid range on the needle and then an agusto running at say 20/21 degrees (depending how it has been set) at low revs agitating the issue.
All the new gizmos are excellent for performance but it does mean you have to be more exact in your set up. a lot of people set the agustos to run at say 24 degrees going down to say 17 but in my personal opinion that is too advanced at lower revs and certainly too advanced on high performance kits for touring....
Just my opinion :D
Donnie
Timbo wrote:Being told by grown ups that my Augusto may well have caused my problems...
Feck me, it's an electrical problem??? :shock:
Donnie.
Old crow
Main scooter: GP 225
You beat me to it. :D
Operator error again? :roll:
'What kind of a dream is it, in which just before daybreak, I thought I cleared Valhalla, for coming of slain men? I waked the Einherjar, bade valkyries rise up, to strew the bench, and scour the beakers'
Special X
Stew
100's of Lammys getting away with X7 needle because they are running very rich in the low and high range so the weak spot is covered up. Ignition retarder means that at the revs being used its too far advanced making matters worse.
Muppet
which needle is best? :?
C’est la vie
^... there is no 'best'... at least not without knowing exactly what your setup is and what your specific motor requires. Ignition timing, auto advance/retard, compression, pipe choice, cc, barrel spec', and a whole host of other factors will influence what is 'best' for your motor, which might be quite different to the next.
The biggest factor governing how the needle responds is the atomiser that it is paired with, so the 'best' needle question is a bit of a chicken and egg scenario... what's best for use with which atomiser?
Adam
Isn't that more likely to effect the gearbox? :shock:
Special X
On that particular engine a couple of combos that are likely to work well are AS266 with X2 needle or AV266 with X13 needle.
    Users browsing this forum: No registered users and 69 guests
